Thought I'd start taking things apart today. Took the top cover off to look in the carbs but before I inspected them, found this:
For those of you unfamiliar with the engine bay, this is the rubber joint between the air filter and the air intake (01-35-15). Sure enough, there was some crab in the carbs. I've blown all the jets clear and blown a load of mud out of the float chamber and the engine seems to be running better. Think it might take a bit of a run to clear everything out but at least I'm making progress!
