In the yahoo TD group is a listing for several different springs for the 716s.
Also, on my truck, the front has a longer cup pin and another 3/4" (19mm) extension on top of that.
The markings are worn off the springs, so I have no idea what was done. At first, I thought the springs were swapped front to rear and the entensions were added to the front, but I just am not sure... the truck had a Sepson hydraulic winch in front, and once removed the front went up 1".
The air lines are rotted in a couple places, so the air springs don't come into place, and as stated before, the compressor has cycled only twice in the last 9 years..... both times with 1000 lbs +/- in the rear, and at speed over bumps, then turned off . I'd replace the lines if I thought it would make any difference, but that would be if I could put the original springs in the rear.
Ty, I would recommend upping the springs in the rear, or at least installing longer spring cup pins to reduce the load on the air springs.
This is the normal stance for my truck. This is with the 8.25 XZLs... so it is a bit of a climb up into
