** when on a hill in gear I put in clutch and it rolls easily acting as clutch is releasing as it should***
So far
*Rebuilt clutch master as the piston seemed to not return all the way.
*Checked trans fluid and it is full with clean gear oil.
With bell housing inspection plate removed it now has about an inch throw at arm when clutch is floored. The pressure plate and bolts look new so prior owner must have done a clutch job.
Am I on the right path at dropping trans and seeing if I can find something wrong with clutch even if it seems to not be slipping and if so should I pay attention to a certain part with these symptoms or am I going in the wrong direction here?
Hopeing this is not a trans rebuild issue..
Thanks in advance for any advice
