I saw the Volvo yesterday
Cabin fully completed and sat back on the Chassis.
Chassis and cabin wired brushed and no more rust found
14B-T engine dropped off for installation to replace the B30A engine .
All "holes" and been welded up.
Air cond vents installed and air cond grill installed
New Dash is now to be constructed with PTO levers and all winch controls located on the old area above the radiator cover. New radiator cover also made to keep the hot air out.
Rear cabin is not going back on and to be replaced by an all ALLOY tray to save weight we estimate 300-400kg saved.
Seat positions checked and sorted.
Radio and stereo and GPS console to be installed
External ROllcage design and size agreed.
Intellitronix DASH to be installed. - Sacrilige - yes im tossing the original DASH its got 3 sets of instruments in it so we going to function and simplicity - unless someone knows a better dash I can use?
http://www.intellitronix.net/intellitronix_010.htm
Power steering to be installed soon - unfortunately from a FORD
Mercedes brake booster installed under the steering wheel and all other brake stuff tossed.
Two electric winches layed out and ready to install on 8 MM plate and will hang upside down from the chassis just behind the PTO.
Fuel tank (150L or 37Gallons being designed) for left side underneath basically I have 22"*12"*42" to fit a tank in (or 55cm*30*107) minus a bit of angling will give me 150-170 liters) - 3 Batteries to be installed on right side. Air intake to be sneaked out the right side by the rear drivers window with possibly a Toyota Air Box etc fitted.
Pictures later when I get them of the camera later today.
The truck looks so good I just wanna drive it now and its only a shell I just cannot believe the transformation.
If you have ever watched on of those shows where they strip a jaloppy and rebuild it the shop looks just like that
Cabin back on until it needs to be cut for the 14B-T
Front all repaired or replaced rusty parts with thicker gauge steel.
One of the two electric winches to be installed beside the PTO - One forwards and one facing backwards.
From the rear the back of the cabin restored the rust now all gone.
The roof all repaired and wired brushed down
The front right side all fixed and air cond radiator installed
Left front side all repaired and ready
Drivers side seat sitting for me to get checked out and yes new seat is lower so more headroom.
Old engine meet
New engine
Air cond vents being setup and new radiator cover.
