With enough free time you can put what tires you want on a Pinzgauer. These seem to be a little over size for our typical customers use.
http://www.pinzgauer.spb.ru/index.php?o ... =26&id=680
Tire Question
ExpeditionImports
Re: Tire Question
Vallejo, California
www.expedition-imports.com
Vallejo, California
- totaljoint
Re: Tire Question
At first look I thought that was an R/C model. Then I saw the Russian in it!
Re: Tire Question
sweet!!!! ill get a power-steering first!!!!!!!
1985 710MS
1985 712MK
1985 712MK
- GenevaPinz
Re: Tire Question
The cab has been extended (the gray parts), hasn't it?
Maybe for an engine swap...? Anyone can translate from Russian?
Edit:
- the links near the top left and top right corners of the picture mean "previous" and "next";)
- the rear axle has been pushed backwards to accomodate the ginormous tires...!;
- this 712's cab has indeed been extended... but no idea whether this was to make room for a bigger powerplant.
Edit:
Jan
'72 Pinzgauer 710M
'72 Pinzgauer 710M
Re: Tire Question
[quote="GenevaPinz"] Anyone can translate from Russian?
Sort of http://translate.google.com/?hl=en&sl=de&tl=en#
Re: Tire Question
In the side view, the connecting tube between the rear and center axle looks smaller. I wonder if they replicated the original design, only longer. Or if they perhaps used some sort of conventional driveshaft there.- the rear axle has been pushed backwards to accomodate the ginormous tires...!;
