Getting closer to my idle problem solution...
spandit
Post by spandit »
Decided to take the front carb off the vehicle to give it a better clean with less chance of losing bits down the engine. I noticed that there was a spike sticking out of one of the mixture screw holes (inside the carb). Took both screws out to find this:
The most worrying thing is the #1 screw (bottom of picture) as part of it is missing...
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
Re: Getting closer to my idle problem solution...
That would do it. Did you look into the hole? is it in there? If not, hope it broke and someone just tossed the threaded piece back in. You should check for damage to the idle air cavity now vs placing new screws and hoping for the best. I small straight pic should allow you to gently feel inside the area. Compare it to the second
spandit
Post by spandit »
Second carb was just as bad (almost identical, in fact - one snapped, one partly missing). I've ordered 4 more...
Robin
Pinzgauer 710K
MegaJolt ignition
cruzoropeza
Post by cruzoropeza »
Check your manifold gaskets, they will cause alot of issue at idle.
spandit
Post by spandit »
Will do. They're all fairly new but #4 cylinder has to come out anyway so I'll be rechecking them soon
Robin
Pinzgauer 710K
MegaJolt ignition
