Front bumper fabrication
blackstack
About a year ago or so there was a post by a guy who built a front bumper with winch platform. He had pictures and material specs ..it was a really nice instructive post...but I cant find it. Anyone know where it is ? my searches don't find it.
- cruzoropeza
blackstack
Re: Front bumper fabrication
thanks for the link. that isn't the one I am looking for but it is a help.
thanks again
thanks again
Check with the sponsor...Exped. Imports. They sell bumpers, I have one. Very sturdy.
http://s400.photobucket.com/albums/pp88 ... C00270.jpg
I had the hole cut for the pin access.
I'd like to get an EI bumper as well - it looks good! Did you cut the hole in the bumper to retain the pin access, or does EI do that? Where did you get the mesh headlight guards?
I had a metal shop in San Diego cut the hole and weld light weight metal all around to keep out the road debris.
Got the mesh guards from Knuckledown. The 'kit' comes with fasteners to attach the guards top and bottom. I
only attached them at the top so I can lift them to clean the light lens, otherwise there is no room to get my hand
in there for cleaning.
I bought different bolts to fasten the bumper instead of the stock bolts that held the stock two piece bumpers. I
also drilled and tapped holes to attach the spot lights as the bumper is 1/4'' thick metal and takes a tap well. The
holes for the mounting bolts are filled with plastic caps from mailing tubes to keep out 'stuff'' from the trail.
When I had the trailer I made a front hitch from 3'' angle and a pintle hitch from a surplus store. Putting the lunette
into the hole where the pin is did not allow much turning radius for the trailer. Sometimes it was better to 'push' the
trailer than pull it when camping in a tight spot.
http://s400.photobucket.com/albums/pp88 ... MG3362.jpg
blackstack
Scott is out of the bumper business unless he gets enough orders to have another batch made....I was trying to get one of Scotts which is how I found he was out so call Scott and tell him you are interested in getting a bumper !!!!
and thanks krick3tt for the links to your pics....i think they will solve my problem
Bob
Bob
SAV has original Pinz one-piece bumpers with guard for sale. Anybody have experience with these? Are they strong enough for a tow bar, winch, etc? Here's the link.
http://www.pinzgauer.com/showdetails.ph ... 2940700/29
Here are some pics of the one i made back in 2005. Still going strong. This one is designed detachable.
Bernhard
http://www.flickr.com/photos/28195322@N ... 781762691/
Bernhard
Bernhard
1973 712M
1975 710K
2013 Tacoma TRD 4X4
1973 712M
1975 710K
2013 Tacoma TRD 4X4
texas pinzgauer
Thilo Kass in Prescott, AZ may still have some of his well built front bumpers. I had one on my 710 and it was very well made.
1974 712M - sold
1973 710M - sold
1974 712M - sold
1973 710M - sold
Bernhard,
Two questions for you;
Where did you source the Amphenol connectors? I have never seen them that size.
I can see that one is for power to the winch, but what is the one that is capped?
Also, where did you get the connector box for the winch remote?
Bob
Bob
Bob
1990 - Mercedes G-Wagon 250GD
__________________________________________
A goal without a plan is just a wish!
That looks awesome one of the nicest Stock looking Pinz I've seen.bernhard wrote:Here are some pics of the one i made back in 2005. Still going strong. This one is designed detachable.
Bernhard
1974 712M AKA the Banana
1987 718M Now Sold
1975 Volvo TGB1111 Now Sold
1963 404S Now Sold
Thanks guys,
I got the connector here.
Its a Size 40 plug
ITT VEAM, LLC
EC - WATERTOWN Cannon
100 New Wood Rd.
Watertown, CT 06795-3347
Telephone 860-274-9681
Fax 860-274-4963
It cost more then the winch! The second plug is just an extra cover so when the winch is removed you dont foul the plug with dirt. I made the connector box. Trying to keep it looking stock whill adding features.
Its a Size 40 plug
ITT VEAM, LLC
100 New Wood Rd.
Fax 860-274-4963
Bernhard
1973 712M
1975 710K
2013 Tacoma TRD 4X4
1973 712M
1975 710K
2013 Tacoma TRD 4X4
- westernair
I picked up a new Plasma cutter a few weeks ago after getting my Superwinch from Scott at IE. Decided it was time to make a front bumper.
Decided to use 1/4 plate.
I also picked up one of the 24v Humvee aux air compressors and tank. I plan on making a rear bumper and installing them in it.
For the rear bumper I need some help, with ideas on how to make the swinging tire mount. Do people make this out of tubing, as in wending a stub in the bumper and slipping a smaller tube inside to swing out? Or is it best weld in a seat and install a set of bearings?
Shawn
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
Nice looking setup.
You may think about inverting the vertical fairlead roller bolts, in the unlikely event you lose one of the nuts the bolt and roller would be less likely to disappear on the road.
