When 35a of charging power isn't enough
David Dunn
Post by David Dunn »
Just what you power hungry B's need when the 35a alternator doesn't cut it :mrgreen:
http://cgi.ebay.com/ebaymotors/TIERNAY- ... 4cfddabcb2
Re: When 35a of charging power isn't enough
He has had that bad boy for sale MANY times. No one ever seems to bite. I wonder what the purpose of a 28vdc generator was?
David Dunn
audiocontr wrote:.... I wonder what the purpose of a 28vdc generator was?
Being Air Force, an APU for Air Force One's stereo when it's on the ground. :roll: :mrgreen:
NoahDL88
Post by NoahDL88 »
audiocontr wrote: I wonder what the purpose of a 28vdc generator was?
I'm going to go out on a limb and say it was to create 28 volts of the Direct current variety.
I wonder about the thrust they generate, if any at all, Turbine go-Kart anyone?
1972 710K
28v is a common voltage for military aircraft. Many planes do not have batteries onboard and require an external power supply until the engines are started. Our A-4 Skyhawks required an external electrical source as well as a high volume air compressor to start the engine.
This link shows an apu being used to start a Citation.
http://www.youtube.com/watch?v=9C-tUMxD8-w
Makes sense. Thanks.
Very similar to the GSE (ground support equipment) that was used to start the jets on the flight line and the carrier when I was deployed in the Tonkin Gulf for the VietNam war in '65. Also had a hydraulic and high volume air start device for the planes. Never thought I would see that stuff again. Ours was painted yellow.
krick3tt wrote:Very similar to the GSE (ground support equipment) that was used to start the jets on the flight line and the carrier when I was deployed in the Tonkin Gulf for the VietNam war in '65. Also had a hydraulic and high volume air start device for the planes. Never thought I would see that stuff again. Ours was painted yellow.
As an aviation support electrition in the Corp that was why we called it yellow gear. :lol:
