Wheel drive tool press.
I want to fab one. Can anyone supply a blue print ?
Re: Wheel drive tool press.
I use a wedge(to hold the split open) and a porta power to remove the wheel drives.
czarthirteen
Jim LaGuardia wrote:I use a wedge(to hold the split open) and a porta power to remove the wheel drives.
Ditto......not a real Porta Power, but I've got a lot of hydraulic-over-electric rams of assorted sizes...I found one that fit the bill and it was easy-sleazy.
Going back on was another story......but I used my own brand of persuasion. A two-foot long section of a black walnut 8x8 and a 14-pound sledge did the trick.
Pinzgauer 712AMB
VW Passat GLX 4motion wagon
Triumph Sprint ST Executive
1986 VW Golf Diesel (AAZ diesel motor, Quattro drivetrain)
Drives go on very easy if you install the wedge to the gap and then use a come a long to pull it back together(last 1/2")while keeping the alignment pin hole in position. Always avoid using hammers where finesse is needed.
Thanks guys, I'm dreading tearing into it but the differential has been leaking badly for a long time.
