Engine dies when out of gear & slowing down
Engine troubles? Try here.
Mac
Post by Mac »
Hey guys
I just had my mechanic go through and re-program my fuel system, the settings in it before didn't make any sense.... The timing went up, then down...then back up...then the same...down....up 2x... It was all very odd.
Anyway, he messed with it and set it so that it drives much, much better (no Dyno, just experimenting mostly), except for one major issue.... If I'm at speed and take it out of gear so that I can break and come to a stop...my rpms slowly drop down to about 1000, then slowly down to 0. Almost every time I need to take it out to downshift basically- if I put it in N so that I can slow and make a turn...it dies. It will start right back up, or even start itself if I just put it in gear and keep going...but I need to fix this.
Any ideas??
1951 M37 for sale
2003 BMW 330i zHP
Re: Engine dies when out of gear & slowing down
[quote="Mac"]Hey guys
I just had my mechanic go through and re-program my fuel system, the settings in it before didn't make any sense.... The timing whet up, then down...then back up...then the same...down....up 2x... It was all very odd. /quote]
:?: Fuel injected?
Mac
Post by Mac »
Yes, the system the guy in Georgia was working on I believe.
1951 M37 for sale
2003 BMW 330i zHP
Post by Jim LaGuardia »
check for vacuum leaks, several people had issues.............
Cheers, Jim LaGuardia
"Arch Magus of Machines."
Mac
Post by Mac »
Thank you Jim,
How do I go about doing that exactly?
1951 M37 for sale
2003 BMW 330i zHP
Mac
Post by Mac »
If this helps at all- I have found that if I give it a tiny bit of gas before I start breaking (to slow the RPM drop), it doesn't die....as much
1951 M37 for sale
2003 BMW 330i zHP
Mac wrote:Thank you Jim,
To quote one of jims past posts concerning vacume leaks
Jim LaGuardia wrote: I use brake cleaner or carb spray to find the vac leaks.
http://www.youtube.com/watch?v=9CPqbaSgcok
NoahDL88
Post by NoahDL88 »
What is your EFI system using for Idle air control? perhaps it's sticking?
1972 710K
Mac
Post by Mac »
Problem solved! it wasn't a vacuum leak after all (at least I don't think so). Just poor fuel \ timing numbers! Thanks for everyones help!
1951 M37 for sale
2003 BMW 330i zHP
