repairing pin hole in top
What is the best method for repairing a small pin hole in my top?
I discovered it in our torrential downpours we've been having in WA!
I get a nice drip right over the drivers seat!
- McCall Pinz
I haven't tried this yet, but I found a Swiss Army rucksack that is made of the same material as the top and figured I could cut it into a number of patches and contact cement them if needed. If the holes are really pinholes, then I bet a clear tent patch or silicone sealant would work better and be less visible.
Re: repairing pin hole in top
bassman2 wrote:What is the best method for repairing a small pin hole in my top?
You haven’t indicated what the roof is made of; your signature makes no mention what your top is on. 710? 712? K? M? I know I’m nitpicking however knowing if its canvas or steel could make a difference.
Ed
pin holes in top
I bought a second hand cab top for patching material. I have a 710 with the standard top and if you PM me your address I can send you a few small pieces. Indicate size you want.
Morris
Morris
I know this is an old thread, but I found a product I may try. It is called Tear-Aid. Just thought I would share...
http://www.tear-aid.com/default.htm
I bought part of a US military "deuce and a half" vinyl top and cut small patches with rounded corners out of it which I glue in place with HH-66 vinyl cement from the inside of the Pinz top. From the outside you can't even tell it had a hole and was patched. I learned this method from the canvas repair person who I had hired to replace all my windows and modify my top.
Chris.
https://www.supanik.com/pinz
Do you just put it in place or do you have to clamp it with pressure to get it to adhere?
Doesn't look like it. Vinyl requires 24 hours to cure though. The reviews on Cabela's are really good.krick3tt wrote:Do you just put it in place or do you have to clamp it with pressure to get it to adhere?
http://www.tear-aid.com/images/TEARepai ... EV%20G.pdf
For pinholes, the most unsightly repair is just a dab of automotive GOOP. That's what I used, works great, no show.
- David Dunn
With the HH-66, you MUST use pressure for a few minutes... and a majority of the holding force in in that time. The same method is use to make replacement straps for the top. Laminate 3 to 4 layers of the material together and cut into strips.... instant straps.
- westernair
x2stiffler4444 wrote:For pinholes, the most unsightly repair is just a dab of automotive GOOP. That's what I used, works great, no show.
Shawn
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
