Center consoles
westernair
Re: Center consoles
Post by westernair »
Recived mine yesterday, put a coat of orange peal on it and painted it OG. Thanks Mike, I really appreciate it!
Shawn
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
Re: Center consoles
westernair wrote:Recived mine yesterday, put a coat of orange peal on it and painted it OG. Thanks Mike, I really appreciate it!
I am anxiously awaiting mine!! How did you apply the "orange peal?"
texas pinzgauer
Re: Center consoles
Post by texas pinzgauer »
The name of the stuff I used isn't handy right now but it was just a textured spray material from a local hardware store or Home Depot. Note - this stuff was sort of rough to the touch so you might consider sanding it slightly before you go painting it or you'll likely lose some skin on your right elbow when off roading!
1974 712M - sold
1973 710M - sold
Re: Center consoles
while I have not used the spray stuff on the console, I have used it before. I like the texture you get from a 3/8 nap roller better than the spray on stuff. The liner is available in quart cans which should be enough to cover the console and the rollers can be had in the trim size and are fairly cheap.
Just a thought
westernair
Re: Center consoles
I just used "spray tex" set it on medium texture. Takes 5 min to dry and then I painted it with a few coats of SAV Swiss green.
Shawn
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
Re: Center consoles
westernair wrote:I just used "spray tex" set it on medium texture. Takes 5 min to dry and then I painted it with a few coats of SAV Swiss green.
Could you take some pics?
westernair
Re: Center consoles
Shawn
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
texas pinzgauer
Re: Center consoles
"Ribbed for extra pleasure!"
1974 712M - sold
1973 710M - sold
Re: Center consoles
Exorcist!
Re: Center consoles
They look great! Anxiously awaiting mine!
Re: Center consoles
I got mine today...and it is VERY well made! This is so worth the money. I hit it with some rubberized spray to get the texture others have added, then I will paint it OD.
Re: Center consoles
harder to get a console to Canada than to get a southern neighbor into the US. glad it made it.
totaljoint
Re: Center consoles
Post by totaljoint »
We have around 11 million examples that the latter isn't all that difficult.
djw
Re: Center consoles
Post by djw »
Got mine a couple of weeks ago, thanks!
For my installation I had to significantly lower/alter the clips on the console (put the rear on the bottom after grinding a slot in the metal piece, removed the front and put a spacer/washer on the lower screw mount). Tried it first as Krylon Camo and did not like that look, then redid it with Krylon Hammered Black and I think it is a nice look and is consistent with the doghouse.
4-21-2012 11-26-45 AM (Medium).jpg (80.67 KiB) Viewed 7486 times
texas pinzgauer
Re: Center consoles
Looks good!
1974 712M - sold
1973 710M - sold
