Before I spend the money, can anybody confirm that I can make this work with my 710?
http://www.airheadparts.com/vintage-vw- ... 953513-gg/
http://www.airheadparts.com/vintage-vw- ... 1953513-g/
Possible replacement turn signal switch?
spectactical
spectactical
Re: Possible replacement turn signal switch?
And while we are at it, any idea why my links aren't working?
VW part #211953513J was the original Pinz switch but are difficult and expensive to find. The G suffix will work but the wire colors are slightly different and you'll need to experiment a bit. This "guts only" switch is new manufacture and may not work in the original switch housing.
Here's a complete switch of new manufacture: http://www.eisparts.com/211953513G.html
I may have a new one of these around with the wiring diagram for the Pinz I could sell. PM if you're interested.
I just cut & paste the links into my post - there's no need to use the insert URL tool.
I bought a switch from Airhead parts this week, but haven't had time to install it yet. From a '71 Bus.
http://www.airheadparts.com/vintage-vw- ... 11953513-g
michaelh712
I purchased the same aftermarket part from the same company earlier this year. I returned it without installing it as I found it to be flimsy and not well made compared to the real thing. I hope that yours is better.
My current Pinz turn signal switch is so messed up that I have no choice but to make the aftermarket unit work. To me it seems as good as the OEM unit.
Fot the Haflinger I modified a VW turn signal switch and it works perfectly. I re-wired the Haffy from scratch also, the harness was showing its age.
spectactical
Tonight I installed this one http://www.eisparts.com/211953513G.html that I got from pcolette (thanks!) Everything hooked up and is working now. The only issue I had was that the new switch housing wouldnt bolt up to the old ring on the column due to different screw sizes. The old screws were stripped so I had to pull the steering wheel and put the entire new housing on. A little extra work, but it looks better this way anyway.
That is the same unit offered by Airhead parts. With shipping it comes to about the same.
