In the EI video, Scott removes the green wire from the shielded cable and replaces it with the black and red. The black going to the coil and the red going to a 24v power source. Mine still has the green wire going to the coil, and it looks as if the pickup wires are wired in the distributor.... :?: I am hoping this is just another way of installing an E-ignition?
So, can I crimp a spade connector to the green wire coming from the dist and connect that to the NEG terminal on the new coil?
Here is a pic of my distributor internals...
Other than the green wire, I do have a white wire coming from the supressor, which I will connect to the POS terminal of the new coil.
