First time in 24 years a vehicle has left me stranded....not used to it!!
Thanks!Thomas-E wrote:Hi,
You might want to check to be sure that the distributor is properly seated and the retainer is secure. If the distributor climbs up just a little bit it will not work. It must be fully seated to be driven.![]()
Your symptoms sure seem like a timing drive issue.
Best of Luck
If I run the Petronix, I shouldn't have a condenser installed, no?pinzinator wrote:A bad condensor will cause your truck to quit like this. I had a new condensor last about 20 miles on my Haflinger.
Thanks! It is a labour of love!michaelh712 wrote:Berger, your truck is sure giving you a workout and a sharp learning curve. Thank god for this forum or many of us would be in trouble. Lucky for you that you were able to convince the dispatcher for a tow. I had to have my 712 towed home once and the AAA driver refused to tow it as it was a "military vehicle". He said that he could tow a civilian Hummer (heavier and wider), or a Chevy Tahoe, but not a Pinze. Good luck with your troubleshooting.
