This type of unit has always worked well on the rear bumper fabs.
http://compare.ebay.com/like/1906468891 ... s&var=sbar
Front bumper fabrication
Re: Front bumper fabrication
I designed and built this one back at the turn of the century
http://members.westnet.com.au/profpinz/ ... /winch.htm
http://www.ozpinz.com
- westernair
Didn't even know these were available, I was thinking I had to fab my own or go find a donor at a scrap yard. Thanks!4x4Pinz wrote:This type of unit has always worked well on the rear bumper fabs.
Shawn
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
- westernair
I really like your design!Profpinz wrote:I designed and built this one back at the turn of the century![]()
I was looking for something duel purpose, winching and to push over small trees and/or Yugos!
Shawn
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
Has anyone ever used a "nose ring" connected to the pintle mount and used that as a platform to install a removable winch platform? Once u install the nose ring you can use a standard receiver hitch winch mount. Been thinking about putting that together on my Pinz!
John,
I thought about it. Was told that for straight pull it was OK but side pulls might be an issue. Got my 9.5K winch from EI. The roller fairleads make it a non issue for me.
Can double the power with a snatch block.
- totaljoint
Andre Swanson (Fat Fabrications) built my winch platform to plug into either the front or rear 2" receiver on my 712. I carry it in the front receiver, but have only used it once in the rear to pull a stump in a friend's yard.
Morris has a point, it is probably better in this situation to pull head (or tail) on without much side stresses. Here in the Cascades, a tree is almost universally available, so that is not a problem!
The other nice thing about the removable winch is that I can leave it home when I won't be off road. Keeps it dry and saves hauling the weight.
Very slick design.Profpinz wrote:I designed and built this one back at the turn of the century![]()
