So everything is not always as it seems at first!
(This isn't posted in engine cause in the end it wasn't an engine oil leak)
If a LR is not leaking oil then it is out of oilDavid Dunn wrote:I was puzzled by the subject title.."UNexpected oil Leak"
The only time I've seen expected oil leaks were with Land Rovers
Its OK, I'm a LR owner too, and can bash them at will
THAT is an unexpected Unleak...If a LR is not leaking oil then it is out of oil
Bet it was fun when you dipped your finger in it, rubbed it between your 2 fingers... hmm does not feel oily.Squiggas wrote:A similar thing happened to me. One morning I found a trail of liquid coming from my front wheel hub. It didn't feel oily so I thought it must be brake fluid. I cleaned it off and waited for it to reappear to see where it was coming from. It didn't come back and was still dry at the end of the day.
Next morning it was back again. I couldn't see where it was coming from. The brake fluid level hadn't gone down. I was mystified.
On day three the mystery was solved when I saw a dog taking a pee.
