Can someone please measure the width of their Pinz 70" from the ground
I know that overall (rub rail to rub rail) width is 69" but the roll bars slope in so at 70" from the ground it is narrower.
Thanks in advance for any help
Width of a 710m Pinz...
Re: Width of a 710m Pinz...
70" from ground on what height tires? :?:
My 710K at the windshield frame is 61.5” the 710M windshield frame is the same so…
If you include the mirrors (not folded and slightly larger than stock) 85”
At the rear (remember mine is a 710K) 62.5” with no load, I’m sure this would come down to the same as the front with a load.
As can be seen from my front and rear measurements load and tire height would make a difference in an exact measurement.
those are the rough numbers I was looking for - will assume a 710m is same width at top of windshield all the way back?
Thx
Thx
Perhaps the same width...but, taller in the back than the front.
Depends on the load, put a ton of stuff in the back and...krick3tt wrote:Perhaps the same width...but, taller in the back than the front.
I was just looking for general numbers as tire size, load etc could all affect 'exact' measurement but as long as we're within 1/2" +/- it works for what I was looking into.
Thanks!
Thanks!
