Is there a tranny connection for backup lights?
mm58
Post by mm58 »
I just mounted a couple of backup lights to the rear of my K. I was told that the transmission should
have a switch where I can connect my wiring to energize the lights when I shift into reverse.
Can anybody confirm whether this switch actually is there? and if so, where exactly?
Thanks...
'76 710K
Re: Is there a tranny connection for backup lights?
You will most likely need this: http://www.expedition-imports.com/produ ... gauer.html unless a previous owner has already installed it.
mm58
Post by mm58 »
Thanks for the link Paul. I guess I will need one of those. I just looked at mine, and there is no switch installed.
'76 710K
