I just bought the Cannon Challenger 24-Gun Safe sold at TSC stores in the US, (heading to Ogdensburg to get it) because it is on-sale right now. I know it isn't a Fort Knox safe, but for the money and features, the equivalent safe close to me is about double.
Howdy,
I purchased a Cannon Safe at the Great Western Gun Show at the L.A. County Fair grounds in the mid 80's. (Back when L.A. County allowed gun shows) At that time it was manufactured in El Monte, Ca. It doesn't have any mdl.#, just a ser.#. It's 30"w x24"d x67"h. Has a manual combination lock (not electronic) and it is REAL HEAVY. I've moved two times since I got I and had to rent a truck with a lift to get it moved. It is solid as can be.
Cheers, Stevo
You do know you will have problems getting 24 long guns in that without marring them. The safe you listed is 20 x 26 x 60 ext. I have a 24 x 30 x 60 ext. safe and 24 long guns is a tight fit even with bolts removed. Always buy a larger safe than you need. This is the one you want http://www.tractorsupply.com/-3910084
Ya, I figured I would need larger....8 rifles larger, so I should be good. The wife wants the closet back, so i needed something that stands on its own!
Howdy,
While I'm sure that your dimensions of your safe are correct, as I said, I purchased mine in the mid-80's. Over the years, I think that the Cannon Safe Co. possibly changed their safe sizes to accomodate customer demand. Having read your reply, I decided to re-measure my safe; however, this time I did interior dimensions-not the exterior. Width:29.5" - Depth:22" - Height:65"
There is a top shelf which measures 29.5" wide x 22" deep and five shelves which measure 10" wide x 21" deep. There is also a large cavity which measures 18.5" wide x 21" deep x 53" in height. Sorry I didn't make my reply clearer.
Cheers, Stevo
