NEEDED: Headlight parts for 710M
jefffrankphotography
I am looking for headlight parts for my 710M I am needing all parts which are behind the headlight itself. I need the mount in which the headlight sits. If you look at the Pinz I need all the parts which cannot be seen without removing the headlight. mounting ring, plug, springs etc. Image attached is parts catalog 9.70 I am in Phoenix, AZ USA. Thank you.
- Screen shot 2013-04-02 at 11.49.26 PM.png (35.39 KiB) Viewed 1729 times
Re: NEEDED: Headlight parts for 710M
Was Dave not able to help you? Mark has a parts truck also, might give him a call. I will pm you his number.
Headlights are in! Thank you Mike and Matt for the help. Thank you Stan for the parts. Glad I met ya!
