picked up a set of 14x5 Lancia rims today for cheap. My goal is to use these for on road drivers
I may have asked before but what size tires are you running on the 14" rims - can you post a picture of your sidewall please?Garrycol wrote: SNIP
The 14" wheels I have on my haffie have no clearance issues as the offset on the wider wheel means the track is about the same as a haffie with 12" wheels on. However the wheel/tyre is taller and I don't think this help stability. I think that the taller you go the fatter the tyre needs to be and the offset of the wheel needs to move out to maintain stability.
SNIP
Garry
rustywheel2004 wrote:Hey Shawn,
Great looking Bantam you got for yourself, congratulations!
On one of the above posts the question of lug nuts came up. I believe that the original nuts will not work properly i.e. safely on alloy wheels. Rick Fredrick from Palm Desert, CA came up with a custom design for the correct fit a couple years ago and posted photos in the Restorations section of this forum site. You may be able to buy a set of the nuts from Rick. He also made a copy of his CAD drawing available for the asking. If you can't get in contact with Rick I can send you a copy of his CAD drawing.
Steve
Does look like the thread has wondered a bit - sorry.TechMOGogy wrote:So you purchased these lugs vs the link you posted?
10mm x 1.50mm Thread Pitch
http://www.rockymountainatvmc.com/p/43/ ... me-Lug-Nut
The tyres are Hankook Zovac HP W401 M+S - 185R14C 102/100P The aspect ratio is not given but comparing the overall diameter of these with other Zovac of the same width it looks like they have an aspect ratio of 80. From the online specs 185/75R 14 tyre has a diameter of 24.8" and my tyre from the online specs has a diameter of 25.6" (which works out to be 185/80R14). My tyre is the 102/100P near the bottom of this link http://www.hankook.com.ar/img/productos ... =rcldgggkeTechMOGogy wrote:I may have asked before but what size tires are you running on the 14" rims - can you post a picture of your sidewall please?
Also - if you get a chance can you measure the diameter of the tires?
