1-I have noticed that my 710m (with radio truck mod) is higher on the right side than the left side
2-The left front tire is wearing faster on the outside edge and the right front tire is wearing evenly not like it should with wearing on the outside edge. The wear on the left tire is significant where as the wear on the right tire outer edge is almost non- existent. (Level/even)
I went and did some measurements from the top center of the limit strap bolt to the bottom center of the limit strap bolt(IN INCHES)
I did it this way as to just measure the suspension static length/dimensions for comparison purposes.
I did check air pressure and all tires are same type and size. Mileage unknown as I bought this pinz in dec. I have had the tires balanced and rotated in march.
LEFT FRONT= 17..................RIGHT FRONT=17 1/4
LEFT REAR= 17 3/8...............RIGHT REAR=17 3/4
So as far as I have read, I cannot change the camber on the truck. Is this correct? :?:
I am guessing that the tilt to the left is causing the outer edge of the left front tire wearing quicker and at the same time the right front tire is more level to the ground (due to the vehicle tilt) which causes more even tire wear to the right front tire
SO WHAT COULD BE THE CAUSE? :?:
SPRINGS? :?:
OR???? :?:
THANKS
