speedo problems
mike43
speedo problems
Post by mike43 »
The speedo has stopped in the 712. So I disconnected the speedo cable from the back of the speedo.When driving the end of the cable is not spinning around, any ideas please. Thanks Mike.
Re: speedo problems
first step check for broken cable
compunerdy
Re: speedo problems
Post by compunerdy »
Speedo cable goes down to the front differential and connects to a adapter that has a little metal piece that drives the cable from the gear. As edzz said you can unscrew the cable at both ends and see if it is broken.
Tim
1975 710K
mike43
Re: speedo problems
Post by mike43 »
I have removed the cable and it isnt broken so it seems like something lower. Is the rest of it easy to get out and work on? Thanks Mike.
Stekay
Re: speedo problems
Post by Stekay »
'76 710K
mike43
Re: speedo problems
Post by mike43 »
Thanks for the drawing, if I disconnect the speedo cable and then try and turn the shaft in the drawing and it turns then does it mean that the cog end is broken? Thanks Mike.
Stekay
Re: speedo problems
Post by Stekay »
Yeah, you need to remove item #2 and withdraw the pieces through the hole in the front chassis support. Doesn't look like fun. You might have to "customize" a wrench.
'76 710K
