I can't figure out from drawing what this is extra outlet is for?
What is this part of heat exchanger for?
- 11-14-2013 1-31-57 PM.jpg (120.46 KiB) Viewed 2091 times
Re: What is this part of heat exchanger for?
Is that the one for the air intake pre-heater(?)
'76 710K
'76 710K
Yes it is though I've not seen a heat exchanger with that port operational. My pre-heaters connect to the heater valve (item #61).mm58 wrote:Is that the one for the air intake pre-heater(?)
There's a grill on the wall above the access port in the rear floor on a K. Is it possible this is a variant for that truck?
That grill is for the BN4 gas fired heater that is behind the driver's seat on a K
undysworld wrote:There's a grill on the wall above the access port in the rear floor on a K. Is it possible this is a variant for that truck?
'76 710K
'76 710K
