engine misfire
Re: engine misfire
The solenoid must pull in to close the contacts to power the starter, so if it is spinning then the solenoid should be OK. However, the one way clutch that would allow the engine to spin faster when it starts (the "Bendix") has been known to fail; I had the same issue where the starter would whine but the engine wouldn't crank -- replacing the Bendix was the solution. When it fails, it isn't a one way clutch anymore, it is a "no way" clutch since it won't drive in the direction it should. You can't tell by feel since it seems right by finger pressure but it slips with real torque like trying to crank.
Re: engine misfire
Bummer - all this knowledge about leave for the mainland where there are already a bunch of wizards! On the bright side if you can't get it humming all you have to do is get to LinDen Engineering and see what Dennis can find. That and some high altitude jets . . . If I had to leave Hawaii you can bet Colorado would be at the top of the list!HawaiianGauer wrote:Good reminder of how lucky I am to have nice wx year round! If it makes you feel any better, Uncle Sam will be moving us to Colorado in a few months...McCall Pinz wrote:I wish I was working on your Pinz today instead of mine- we'll have a high of 29. This is actually balmy for Jan here, so I'm taking advantage of the warm weather!
Stuck in the bureaucratic spin cycle!
compunerdy
Re: engine misfire
After checking compression, adjusting valves, and rebuilding cards to no end.. It ended up being a bad brand new spark plug. DOH!!
Tim
1975 710K
1975 710K
- HawaiianGauer
Re: engine misfire
so I replaced the starter - pretty easy, no drama. fired her up no problem! went for a nice little ride, knocked out an errand, got some gas, and on the way home, the clutch went out.
Mahalo for your assistance!
Harry X.
73 'Gauer 712M
Harry X.
73 'Gauer 712M
Re: engine misfire
Just a guess without a better description of “the clutch went out ”.
On the assumption that you pulled the slave cylinder for the clutch to facilitate the R&R of the starter that’s the first place I’d look. Possibly things just didn't get set correctly on reassembly.
- HawaiianGauer
Re: engine misfire
Thanks for the feedback! I have been trying not to drift off the orig thread topic, which I already did with my starter comments...and now my clutch problem! I was really just whining out loud about the two...I mean, I finally made some no-kidding progress, while learning a ton in the process about timing, mixture, etc art work related to the whole engine sputtering/misfiring issues. Then the starter goes, which was not too big a deal work-wise, just annoying timing...and now the clutch! Arghhhhhhhhhhhhhhhh!edzz wrote:Just a guess without a better description of “the clutch went out ”.
Anyway...whining over!
If anyone has any lessons learned, words of wisdom on getting after the clutch - I'd be HAPPY to take your advice! Probably best to PM me though!
x
Harry X.
73 'Gauer 712M
Harry X.
73 'Gauer 712M
Re: engine misfire
"get the throwout bearing and pilot bearing"words of wisdom on getting after the clutch
'76 710K
