Blinker indicator on dash
I thought my blinkers were not working because there was only intermittent operation of the indicator light on the panel. I pulled the switch and it seemed ok and when I put it back together I found the blinker lights were but the bulb inside was not. I messed with the indicator light itself and it seemed to have a weak connection. I tightened up and now the blinkers work fine, but the indicator light just stays light when the blinkers are on. It does not blink is this normal are should it blink?
Jim Chance
710M
710M
Re: Blinker indicator on dash
Replace the flasher.
