Grounding.
Grounding.
Which pole of the batteries is typically grounded?
Jim Chance
710M
710M
Re: Grounding.
Pinzgauers are negative ground.JimmyC wrote:Which pole of the batteries is typically grounded?
Remember the battery cutoff switch interrupts the ground circuit. if you ground any thing directly to the battery you are potentially defeating the system. there is also a relay in the cutoff circuit that is intended to temporarily maintain the circuit in the event the battery cutoff switch is switched off when the engine is still running to prevent alternator damage.
Did any of that make sense?
Re: Grounding.
Well to answer your question directly.. the negative pole is grounded lol
Tim
1975 710K
1975 710K
Re: Grounding.
Yes negative is grounded, however not by a single ground strap directly to the chassis as would be done with most vehicles.compunerdy wrote:Well to answer your question directly.. the negative pole is grounded lol
Re: Grounding.
It is on mine.. but that is because I redid my wiring.edzz wrote:Yes negative is grounded, however not by a single ground strap directly to the chassis as would be done with most vehicles.compunerdy wrote:Well to answer your question directly.. the negative pole is grounded lol
Tim
1975 710K
1975 710K
Re: Grounding.
Actually only the negative post of one battery is grounded - its a 24vdc system.
