Yay! an audio question! I'm trying to be difficult btw
1) You installed an audio system. You did poorly at implementing a stereo. You're better off running it in mono with your current speaker locations, sorta like a 70v ceiling speaker PA system in a hotel lobby.
2) More tweeters does not equal more better sound.
The install looks nice. Good for you for implementing a sub (curious if your headlights dim) as it adds a lot of missing content. Where did you put it? Ported? Sealed? Can you fit a lil bandpass somewhere for the added volume?
In regards to spatial perception, or stereo "triangulation", its a function of space & time. Or in our case, distance and time. The audio was recorded with the intention of the left and right information arriving to the listener at the same time (across the frequency spectrum). This is accomplished by equalizing the distance of the left and right speakers on a common plane. When you shorten the distance to one speaker, you create a left\right bias, and your brain perceives you're positioned in a totally different position than the audio engineer imagined. You wont die. It simply wont sound as intended.
There are ways to compensate. Introduce a time delay on the closest speaker and you can start to trick your mind. Or place the speakers as far away from the listener as possible to decrease the delta (kick panels)
The same notion of distance applies across frequencies. In a coaxial, the tweeter is a couple inches closer to the listener than the midrange woofer. This means the high frequencies are arriving sooner than the mids by a ms and should also cause a spatial issue with your minds perception. by separating the tweeter from the woofer, you can install the voicecoils on a common plane, equalizing the distance. No one really takes advantage of the true reason they're separated in car audio and just install separates because some marketing genius back in the day made us all think that separates = better. Its not entirely true.
Brings us back to your install. You have 4 tweeters, two mids and a sub. Why all the tweeters?
This is all a purist argument which is absolutely silly in a pinzgauer. Get some sound in there and move on.
