electric fan in my 303
Cole Wilson
I just wanted to let you know about my favorite modification. I placed a 16" electric fan on my 303 and built a custom fiberglass shroud. This modification made a huge difference. It gave me a little more power but the noise inside the cab was greatly reduced. Caution the fan without the shroud did not cool enough at high speed, however it cooled better at low speed due to the constent speed of the fan.
Lightningpinz
Volvo Cooling
The Volvo is right on the limits of cooling in the stock configuration. We have been changing out for a modified extra thick core radiator. The electric fan is also a good idea. We have done one. The customer wanted an override switch so he could turn the unit on by his command instead of the thermostat. I liked the idea of a cut off switch for fording water.(turn the prop off)
