You're pretty brave putting your hands iinto that goo! With a little radiation thrown in, you may turn into Swamp Thing.
Diff leaks? (visual included)
- David Dunn
Re: Diff leaks? (visual included)
Peter,
Well my hands do glow at night now, Dave, but it's very handy when working on the Pinny in low light
1997, 718 6X6 Pinzgauer
Thanks Profpinz for the precision. Too bad to loose such a brilliant mecanic just for years of undermaintenance...
And as you said, be aware of boot!
- David Dunn
Well Peter, you may want to see a doctor when your shaving stubble is moss and your ankles and wrists develop portals
But the later might be a good thing for those hard to reach places on the Pinz.
You guys are freaking me out.
I have changed oil in everything, it was dark but not goo. How do you know without a complete tear-down?
You can have a look through oil change plugs. Use a flash light to see clear.
goranvolvo
when you got all that apart do the seal to under # 37martinlbb wrote:Thanks for your feedbacks!
OK for o-ring, I'll do it.
For your cork, I got it: this is part number 900.3139, called "Plug" (french translation is closer to cork word).
This is part number 19 on this close-up.
Thanks all for your help, I appreciate
Well, everything is rebuild up. I changed all o'ring aand gaskets. Works wonderfull now
I have the sudden compelling urge to change all of my fluids......
