Front carb fuel fitting wanted
Post by pinzinator »
I'm looking for the fuel fitting that feeds the front carb, the rubber fuel line connects to it. It is a single inlet banjo fitting, the rear is dual, since the rear carb feeds the front and rear together. If you have one available please PM me with a price.
GRCameron
Re: Front carb fuel fitting wanted
Post by GRCameron »
You might find what you need at BelMetric.com. They have been prompt and their prices seem good. Here is a link:
https://www.belmetric.com/banjo-eye-fit ... bd3cs19ek7
George Cameron
Yarnell, AZ
1979 Pinz 710M
Molon Labe
Thanks for the link! The banjo bolt is M12 X 1.25 so it was easy to find the one I needed.
Garrycol
Post by Garrycol »
I recently had the same issue and could not find one anywhere - no auto parts places had them.
I then went to a diesel tuning specialist (Cooma Diesels here) and that had exactly what was required - threads were not an issue. They use them on their diesel connections for fuel pumps and filters etc so had a large range. The banjo and hollow bolt were relatively cheap so try your local diesel specialist.
1973 Haflinger AP700
1977 Landrover FC 101
2007 Range Rover Sport TDV6
1957 Landrover 88"
