As for fitting an M14....
Phil
Prof,Profpinz wrote:Re gasket thickness, I asked a similar question of some of the experts on Robi's Forum (German Pinzgauer & Haflinger Forum) in particular WF who knows Pinzgauer's backwards.....his expertise is well known on the Forum.
I was told to always fit the thickest MLS gasket available (ie. 3 notch) and that in Europe VW/AUDI repairs normally fit the thickest gasket as standard.
The following reasons were given:
1/. It minimise the smoke/dust layer on the valves and pistons.
3/. The slightly lower compression increases motor durability/life particularly under high boost.
It took me about 2-3 weeks of trying and finally I got registered. No clue why but same as you I was trying to use Google translateNM_Mogman wrote:Thanks! It does make sense to ask on that forum.
EDIT! I lived in Germany for six years...as a child. This presents a problem as the security questions are all in German and I can't seem to get an answer correct, even after a translation.
