snow plow for 712
snow plow for 712
I do not know if this subject has been addressed, ether way, I want to install a plow on my newly acquired 83 712 . I bought it over the holiday in N. Ky. A very original example. The main reason I bought it was to use it for limited snow plow work on my very steep driveway Not sure where to start so anyone out there have any thing to add let me know ! I know in Europe they are fitted with plows. Anyone know where I can get one ?
Re: snow plow for 712
Maybe you can get some ideas from this eBay listing: http://www.ebay.com/itm/1983-PINZGAUER- ... 1740501692
- Jimm391730
I have seen one with a factory plow; the plow is pushed though a clamped pivot just behind the front diff (clamps around the main chassis tube), and the plow has arms that reach back, under the diff and front axles, to that point. Then the lifting of the plow is done from the front of the frame.
i was considering that unit before it went on ebay....if it had been a 712 i might have bought it, its a total custom truck right down to the Diesel engine by Fiat .pcolette wrote:Maybe you can get some ideas from this eBay listing: http://www.ebay.com/itm/1983-PINZGAUER- ... 1740501692
any pictures?Jimm391730 wrote:I have seen one with a factory plow; the plow is pushed though a clamped pivot just behind the front diff (clamps around the main chassis tube), and the plow has arms that reach back, under the diff and front axles, to that point. Then the lifting of the plow is done from the front of the frame.
Please add your location in your profile.
hint
User Control Panel / Profile
hint
1997, 718 6X6 Pinzgauer
Have you considered a drag behind plow? With chains and the pintle hitch an old style farm plow/grader might do the trick. It will also make the truck less prone to damage from plow impacts. It sounds like you have to nice a truck to beat it up. That's what Chev's are for.
Do I sound like a guy who started out with draft horses? Oh well...
Cheers, Clive
Cheers, Clive
- Jimm391730
From foggy memory, I think this was broached many years ago here. IIRC, someone compared it to a really old John Deere snow plow.
- David Dunn
Nah,Jimm391730 wrote:That's Peter in January!
Peter took a road trip to Antarctica. .. He had a hankering for fresh penguin . taste like chicken
BTW..If that was Peter's place, it had to be the coldest summer on record.
63rover wrote:Have you considered a drag behind plow? With chains and the pintle hitch an old style farm plow/grader might do the trick. It will also make the truck less prone to damage from plow impacts. It sounds like you have to nice a truck to beat it up. That's what Chev's are for.![]()
Cheers, Clive
NO. do you know where I live ? 300 inches is not uncommon on Superiors south shore. often 2 foot overnight,. also very steep driveway up the side of a mountain....you only get one shot from my heated garage down grade ( cant plow up hill)
Not to be funny but a desiel Mog with hydraulics would be better than an air cooled Pinz
Sorry I know that is not helpful but not many were built to handle plows
Sounds like a snow cat might do a better job on the driveway. I know there are some older ones for sale up that way. Might be a cheaper option.
WOW! Maybe Matt-Tracks and over the top or just hibernate! Good luck!
