Idle Mixture Screws - Which Style Do You Have?
Technical articles by owners, for owners.
Locked
ExpeditionImports
Post by ExpeditionImports »
One of the Most Common Questions we get when people are ordering carb kits. Here are some pictures to help you determine.
Vallejo, California
www.expedition-imports.com
Re: Idle Mixture Screws - Which Style Do You Have?
Post by stiffler4444 »
thanks, helpful visual!
waterdog
Paraguay
Post by waterdog »
where are the solenoids on the large idle screws carb ???? same spot????
1985 710MS
1985 712MK
Same spots...
waterdog wrote:where are the solenoids on the large idle screws carb ???? same spot????
I’d guess the large screw carb is not setup as a Pinz carb, as the accelerator pump linkage and fuel inlet are also different. My guess is that Scott was only interested in answering the common question of small vs large screw. I’d also guess is that the one with the fuel solenoids is for a Pinz and the other is for a Unimog. Am I close?
Locked
