Engine tin powder coated
Post by pinzinator »
I took the time to remove the engine cover tin from my engine and get it powder coated. I have wanted to do this for 5 years, and finally did it since it's been too hot to drive anyway. The new air cleaner is a K&N RF-1015 if anyone wants to try it out.
Here is a short video-
https://youtu.be/YbRSk7Czhs8
Fentonite
Re: Engine tin powder coated
Post by Fentonite »
That looks great!
Now to get a transparent doghouse cover to show it off. One of the best old engines I have seen.
Very nice!
I might have to add that to my winter projects list.
GRCameron
Post by GRCameron »
Looks better than new. Outstanding!
George Cameron
Yarnell, AZ
1979 Pinz 710M
Molon Labe
Jack Russell Racing
Post by Jack Russell Racing »
Holy moly! Mine looks like the dog's lunch compared to that. :(
oilcan
Post by oilcan »
beautiful motor.
question from a novice - that intake looks a lot more free flowing than the stock part. does this allow more o2 into the engine and affect the fuel / o2 mixture? or is that adjustment handled in the carb? or do you have to adjust the carb separately?
thanks and nice work
:!: NICE :!:
Something that resembles a distributor on the opposite side to mine. I'm curious.
krick3tt wrote:Something that resembles a distributor on the opposite side to mine. I'm curious.
That's the coil pack for the Pinz SSI ignition that replaces the stock distributor. Great upgrade!
This isn't a difficult or expensive upgrade if someone wants to do the same. The carbs don't have to come off, so you won't have to re-syncronize them. All you need are very basic hand tools and some patience. It is a good time to replace the fan seal and/or the cover seal, both of which are reasonably priced. The cylinder fins can be cleaned, too, and the alternator connections can be checked. Note the electric fuel pump/pressure regulator- this combination works great but is very difficult to install.
I can recommend a shop that does great powder coating work if you PM me with that request.
How did you do the fan - looks new!
The fan is new, I kept the old one as a spare. I painted the fan housing with 2000 degree brake caliper paint so it would stay on without flaking, as it does get hot.
I'll replace the vacuum booster hose the next time I have the engine cover off, it's original.
Ah... thx... I was hoping for some secret on how to clean plastic to make it look new :)
Cheers!
ako
Post by ako »
Looks great! Job well done.
Was your fuel pump worn out or did you just want an electric one?
Edit : Just found your fuel pump thread. Thanks for sharing the details.
