Ther manual says to check the internal face is 285mm standard and 287mm at the wear limit. Will get the verniers out for that job.
The manual says to put the bolts in the two extra holes to force the drum off. For those of you in America who might need to order in some bolts before the job, you a metric M10 x 45mm (or so) length bolt.
Screwing in the bolts at an equal rate will get you to this position :
View of the brake linings and the hub. This side seems more worn than the others. Will need to check measurements again :
So now I have removed all the rust from the outside face which mates up to the rim. Note the hammer strikes on the face from the previous 'mechanics' :
And cleaned up the inside face which mates to the hub :
So now my question - would you consider painting any of the surfaces to prevent rust coming back. Something like a VHT high temp paint?
Of course I would mask up the contact (braking) surface before painting.
My concern would be the layer of paint would prevent the drums from radiating the heat away. Never done much work on drum brakes before, so putting this one out to the experts.
On the other hand I get anal retentive about rust and lie in bed at night worrying about it
Thanks for any advice offered.
