WANTED! Zenith Carb manifold
Heinkeljb
Post by Heinkeljb »
I have managed to break pre-heat pipe on Lurch as I drove back from Holland the other weekend. It has broken right at the joint to the square manifold / Carb mounting block. It does not look like it is going to be an easy repair as the original pipes are brazed in and if I heat the area enough to melt new braze it, it is likely that it will loosen the other pipe next to it and possibly change angles etc.
SoI thought I would aslk if anyone has a spare Carb manifold for sale? I actually have 2 spares, but they are for the Solex Carb and so won't be usable with the Zenith Carb fitted to Lurch.
Let me know please.
John
