1971 Steyr Puch Haflinger Pathfinder 700 AP, Fresh Restoration, Body removed, rust repaired, new finish applied to all metal panels. New Master cylinder, wheel cylinders, lines and linings. Engine Rebuilt with added strength, 35+ HP Kohler V-twin, insert bearings on billet rods, bored + .030 Over, Total Seal Pistons and Rings, Approx. compression 10:1, Precision Cams "CHEETAH" cam, Flat Tappets, Roller Rocker arms, New stainless steel valves and springs. New Oil Pump in Engine. New Clutch linings. Steering components replaced from below the steering box to wheels. New Upholstery out of the Netherlands ( Faux black leather). New Glass. New Tires and Rims with 750 lb. Load capacity each. (Have the original 5 rims with Semperit tires) LED Headlights and rear light bulbs. Body has been painted with tintable bed liner on all but upper cab of the body. New seat belts. The body has not been cut in any manner to prevent the original motor from being re-installed (I do not have the original motor)
Unit was purchased from the upstate of South Carolina 1 Year ago. Was utilized in front of a business for advertisement for many years. Purchased from another private owner who was going to rebuild the unit but fell on tough times.
1971 Steyr Puch Haflingher Pathfinder on Ebay
managrmark
- Haflinger 1.jpg (368.73 KiB) Viewed 4505 times
- audiocontr
Re: 1971 Steyr Puch Haflingher Pathfinder on Ebay
Nice haflinger. 18k buy it now.
- cascade.king
This one went through quite a restoration, based on his documentation of the rebuild on Facebook. Mark appears to be a very skilled fabricator. I'd be interested to see if it's got a title, and how the Kohler unit does.. Usually premium prices are saved for intact power plants.
Great restoration work considering what the body looked like!
The non-SDP motor will reduce the price IMHO
Good luck and hope it sells quickly for you.
- cascade.king
It's been stalled at $8,600 (still below the reserve). It's worth more than that, for sure. 5 hours left..
Good morning,
Do you have any other pictures ? Video? you can provide. Would like to talk to you about the truck in depth if possible. Please email me at ivanroman@me.com and we can trade numbers, thanks
Ivan
Ivan
