So this made me think about it, since I have a 20lb tank...
One pound of Co2 equals 8.7 cubic feet at standard pressure (~14psi). A typical offroad tire might have 1.5 cubic feet of space in it, at 14 psi you would be squeezing 3 cubic feet into it (since 14psi in the tire is double the normal atmospheric pressure), and 4.5 cubic feet at ~28 psi. So that means you can completely air up two good sized tires with 1lb of Co2; my 20 lb tank could do 40 tires. A ten pound tank should be able to do 20 tires from zero to 28psi (or add 28psi to whatever the tire was aired down to).
Thats a pretty good solution compared to compressed air. Because the CO2 is in liquid form, you get the equivalent of about 160 cubic feet of air @ 2100 PSI with 20 lbs. of CO2. I think that adding 25 PSI to 40 tires is about the right #.
It's an old thread but the newest one I could find. The price of filling my 20lb CO2 tanks at work is closer to $30 these days. We use them all the time for welding and a plumbing freeze kit. I'm looking hard at an onboard compressor. I like the idea of a tank but when you run out, you run out. How is that a better solution than air available on tap whenever you need it? I agree that there's no ability to run air tools with such small capacity, but seriously? As a go to? A tank?
Seriously, letting a CO2 tank get that low is like waiting until your fuel tank get to empty before refueling in the middle of nowhere. And some of us do carry a compressor and a power tank. An air compressor usually doesn’t have the volume to re-seat a popped bead. Also, would you rather be under a truck on a hot, dirty trail for hours trying to break a bolt loose (that hadn't been off since new) , or use an impact and be done in few minutes ( and possibly not be working into the night). There are arguments for both ways, and a CO2 tank is worthless if you don't keep it operationally filled.
I carry both a power tank and onboard air compressor. It would be very easy for me to give up my power tank. The onboard compressor is used way more and with the pinz, space is very limited. Carrying air impact tools is just not practical unless you are a mobile mechanic and that is all you are doing.
One problem that keeps coming up with the power tank is the regulator freezing up. The power tank is best used when air is needed in short, high pressure situations. As Dave has mentioned, resetting a tire bead.
Inhave a powertank and a small aligator clip style bagged off road compressor. I use the tank all the time. Its mounted behind my head on the troop side of the cage and locked. I air up bike tires, classic car tires, wheelborrow and charge my roadshower with it. $10 to $20 cash bill to fill depending on whos at the local shop. They do it while I wait when im running to grab lunch. Sometimes its half full others its almost empty. I have never run it out completely and will always own one.
Excellent. Thank you both for the recommendations. Barring the use of air tools (I am not usually going to be in the outback, far away from civilization) I still think an onboard compressor is the way to go for my needs. Any recommendations?
TechMOGogy wrote:uh ho - we are going to start the 12v from 1 battery discussion now
I hope not. I do a fair amount of work with 120/240V. I also employ the use of a few 48V golf carts and utility vehicles. I don't understand why someone would jeopardize their electrical system or their batteries by avoiding a 24V to 12V converter?
