TOP 10 best Pinzgauer modifications for improving performanc
- audiocontr
Re: TOP 10 best Pinzgauer modifications for improving perfor
cannot view the image
ppearse wrote:I am not sure where this belongs but I thought a mod about performance would be the best place to start. My 710M came with an ignition mod that i have no clue and would love to know what it is. Please see the pic.
Looks like a 24v to 12v converter to me, I'm guessing you will find it to have one wire attached to the "in" at 24v, a common ground wire and a 12v output from the location marked "out".
I suspect if you have an aftermarket ignition system this is dropping the voltage down for that system
BTW Welcome aboard and where in the world are you?
Thanks!
I am in Issaquah, WA. I do have an aftermarket ignition so interesting they chose a downstep like this.
- GadgetPhreak
We should meet up at some point. I recommend Mule Expedition Outfitters in Issaquah for custom/fab work. They've done some work on my Pinz. I also recommend G&M Transmission and Auto Repair in Bellevue. They have some old Porsche specialist guys in the shop and they've been building up their Pinz knowledge doing some work on some of the local machines. They are fairly priced and quite good mechanically.ppearse wrote:Thanks!
Most aftermarket ignitions are 12v, using a 24v to 12v converter is the preferred way to provide 12v for 12v add on's such as ignition, fuel injection, radios, etc. The converters are much easier on your batteries than center tapping.ppearse wrote:Thanks!
Issauqah? seems I've heard of that place before
"We were evicted from our hole in the ground, we had to go and live in a lake."edzz wrote:I was grew up about 10 miles west of you in the middle of a lake.
1:34 https://www.youtube.com/watch?v=Xe1a1wHxTyo
...and you tell that to kids these days, they won't believe you.
Looks like a homemade capacitive discharge system for improved spark.
