it is a reflective silver.
My specialty coating guy prepped and ceramic coated this one silver, like a new one.
Right now it's a little bit shiny silver, but he tells me with time and weather it will dull a little bit.
The good: It is in perfect working condition. The interior fins are clean, having just been polished,
and the ceramic coating will outperform any normally painted heat exchanger.
The bad: Before this refurbishment it was pretty rusted up. There is some mottling in a few places,
but all the rust was removed and the ceramic coat should prevent any further rust. Also, the
understudy of my ceramic coat guy missed the fact that there were some small holes after the rust
was removed so they weren't welded up. Instead of trying to remove ceramic coating and weld,
I used a special putty to cover the holes. They were about 1 mm x 7 mm near the bolt end,
2mm x 2mm on the top, and another couple small 2mm x 2 mm holes at the end on the top.
The patches are on the top and inside, so they should not be visible when installed.
IF you could find one, a used one would cost $650 and a "new" one $1100 plus shipping. I think this one
is worth $950 including shipping to the continental U.S.
The bad:
BEFORE (after ceramic coating, but before patch)
AFTER
