new Pinzgauer owner to be
m9184
United Arab Emirates
Post by m9184 »
Dear real4x4 forum folks,
im an old time G wagon W460 - W461 guy and i have got across a potential Pinzgauer for sale in my country ,
i have enrolled in this forum to get the support and advises on some topics that might be a decision making factor for me and i do appreciate the knowledge and experience i have see in this forum ,,
the car im planning to buy has the following detailed numbers:
712M
-vehicle No: 4704889
-engine No: 5766849
-chassis No: 4754840
1- since i live in dubai, UAE , middle east : where the temperature hits in summer above 55C" - 60C , and the car has a petrol air-cooled engine, will it be working normally in this tough weather in the desert ?>
2- is there any issues and known challenges that i need to look at while inspecting the car and making sure they work properly?
3- what service and overall mechanic maintenance work that i need to do once i get the car home ?
4- is there any video and documentation on how to drive/test the gears , the differential locks , shafts , 4x4, etc.
5-finally : what could be the fair value for such an ex-military car which needs some restoration and work to be done.?
thanks and best regards
Joeri
Belgium
Re: new Pinzgauer owner to be
Post by Joeri »
Dubai....dont they have the TD pinzgauers in their army like Oman and Saudi Arabia :oops:
m9184
Post by m9184 »
Joeri wrote: Sun Nov 01, 2020 6:31 am Dubai....dont they have the TD pinzgauers in their army like Oman and Saudi Arabia :oops:
not sure about those. but I beleive the TD ones are water cooled..
the one I'm getting is air-cooled petrol 4 cylinder
Joeri
Belgium
Post by Joeri »
Yes i know but they are in someways beter than the petrol ones due to having discbrakes, powersteering, and automatic gearbox ( most of them) . The petrol ones.....well if the drive train and engine are ok you cant go wrong so look if there are no big oil leaks under the axles, hi/ lo gearbox , check if the engine turns over and for the rest make sure it is as complete as possible :wink:
m9184
Post by m9184 »
thanks a lot
Hotzenplotz
Austria
Post by Hotzenplotz »
don't worry about air cooled engines; they are designed to work at a wide range of temperatures, and your radiator won't leak :-)
the disk brakes area definite advantage over the drums, automatic vs. manual shift is a matter of personal preference, but the petrol trucks are usually half the price of a Diesel.
Albert
Joeri
Belgium
Post by Joeri »
Hotzenplotz wrote: Sun Nov 29, 2020 2:50 am don't worry about air cooled engines; they are designed to work at a wide range of temperatures, and your radiator won't leak :-)
You forget powersteering :wink:
Hotzenplotz
Austria
apologies, I do have powersteering in my 712
I got used to it way too quickly
Albert
Joeri
Belgium
Post by Joeri »
Thats no powersteering....that is a " i will help you steering" electric unit, cant compare it with a hydraulic steering. :mrgreen:
But if it works... 8) :roll: :wink:
