But, these aren't "New" they are "New Old Stock" cast some 50 years ago.
They won't be perfect. They got moved and kicked around from one storage
loc to another. Qualitatively, they look usable to me. A figure of merit would
be the amount of material needed to seal e.g. the amount from the
inside edge of the Head Bolt hole to the outside edge of the combustion
chamber. Looks like you got at least that even at the damaged area. I've
seen worse used ones that sealed just fine. Here's what I recommend:
Get a high quality German made flat file. Place the file on the top rim of each
cylinder and just carefully run around the top surface to remove any burrs.
No removal of material other than burrs ONLY as they will mar up the soft
aluminum head surface. Next up:
Even if the heads were perfect to the eye they STILL need some hand lapping
to match fit each head to it's respective cylinder. I would also put witness
marks on each component: "One dot" mark on Cylinder #1 and Head #1, a
"Two dot mark" on Cyl #2 and Head #2 ect. INSPECT EACH cylinder CAREFULLY
At one point in time Cylinder #3 was machined slightly differently than the
other 3 cylinders -- yours may all be identical. But if one is unique around the
fins (in the up direction when installed) then that is #3. Oh, I almost forgot.
Measure the length of your cylinders, from the top surface to the bottom
flange that rests up against the engine block. There are three different lengths
yours should ALL BE IDENTICAL -- just to confirm S-Tec didn't make a mistake.
The shortest length was for higher compression. I believe spare parts are mid-length?
BEFORE you insert the pistons hand lap these mating components. I find
it easiest to lock the cylinder in a large vise, apply Valve seating compound
onto the surface then place the head in place and grind away. Use water
soluble valve lapping compound not oil based -- either works fine but oil based
is just MESSY. When done clean thoroughly with brake cleaner if you can get
it or isopropyl alcohol.
In the course of doing the lapping, a lot of that surface damage will be removed
or at least recessed below the surface -- DO NOT attempt to remove it all !! The
goal is to get a sufficient mating surface not a perfect one -- you have plenty of
meat there for a good seal, just eliminate the surface scars and planarize -- that's all.
