Removing window on 710
CaptainRon
Hello, help......I want to remove the driver's and passenger's side window for clean up/maintenance. Seems pretty easy to do looking at it. I see the 5 bolts below the window frame. After removal I can't seem to get anything to budge. Doesn't that frame piece just come out some how?....don't want to break anything lol....
Re: Removing window on 710
I removed mines some months ago,
The bottom rail was glued, orange arrow,
Had to slide a knife, PITA, but did it.
Hugues
From Switzerland
From Switzerland
CaptainRon
Thank you so much. I'll give it a try. Any resource for new gaskets for bottom rail of window?
Thanks again, Ron
Thanks again, Ron
CaptainRon
Thank you Paul!.....
ChickenPinz
Same as mentioned by others -- mine were tightly stuck and it took some quality time with a thin putty knife and patience so things don't get bent. Likely heating it would help as well.
Be careful when you put it back on that you don't plug up the drain hole.
710K
CaptainRon
I saw those drains, yes. I'll have to replace one side of tubing as it is absent. Does that just shimmy to the bottom of the door through that mid-hole in the door? It doesn't sit on any bottom fitting does it? I see the exit hole but haven't separated the two halves of the door.
Mines were also missing
i just bought a piece of tube and passed it through the door,
it exits a few mm at the bottom, we can see the tube in this picture
Hugues
From Switzerland
From Switzerland
CaptainRon
Thanks for showing me that. I just got some new weather stripping for the windows so that will finish this portion of my truck that is in 500 pieces
CaptainRon
For anyone in the market for drain tubes for the windows this product fits perfectly.
https://www.amazon.com/dp/B085N2RV3W?ps ... ct_details
