installing differential breathers
eric1355
France
Re: installing differential breathers
Post by eric1355 »
Hello
You also have this system which has the advantage of not having any connection with the outside (avoids dust and water ingress).
when the pressure rises the bellows inflate
Eric
https://www.amazon.ca/-/fr/Commander-Ou ... R8WT&psc=1
Hugues
Post by Hugues »
interesting,
how would i install it on the rear diff ?
I guess i need to add some kind of nipple so i can connect this rubber breather ?
i would drill and install the nipple here (red circle) ?
rear diff.jpg (186.29 KiB) Viewed 4807 times
Hugues
From Switzerland
Stumbler
Post by Stumbler »
You'll find that the pressure pushes oil out, but it is highly unlikely that it would be pushed or sucked back in. It's a very small amount of oil too. The problem is usually that it drips or get on the outside of the vehicle at higher speeds. The closed thing looks interesting. I'd like to see how that's installed. The little rubber grommets on the wire are hard to keep from rotting.
rollingpinz
Post by rollingpinz »
I plan on installing diff breathers (fr & r). Is it just a matter of removing the cover and connecting the wires or is there a spring waiting to jump out at me?
Also, is it supposed to be dry (No oil)?
No springs. Just remove, reconnect and install the new one with breather.
