I’m going to buy a power bleeder. Which model do you recommend?
I want to be able to do brakes, clutch, and lockers.
The hydraulic trinity
Power bleeder
Power bleeder
Re: Power bleeder
I've tried the vacuum based bleeder - doesn't work well on these breaks. And it was a quality bleeder.
I've also invested in the pressure based bleeder, works far better but you have to have air tight caps
on the reservoir.
on the reservoir.
Re: Power bleeder
Which model did you buy? Aeromotive has different versions. Metal caps, swivels, etc…
Is there a feature you wish you had or should avoid?
Re: Power bleeder
Motive Power Bleeder with quick disconnect accessories.
This works under pressure not vacuum, works OK.
Re: Power bleeder
Sounds good. What size cap do you use? The “European “ kit includes a 45mm cap. Is that the right size for all three?
Re: Power bleeder
I think it was the 45mm cap, specifically for the middle cap on the brake reservoir.
I don't use this on the Clutch or Lockers, I find it too restrictive a space to get in there.
You may have better luck.
Re: Power bleeder
I just made one with a garden sprayer. Youtube is your friend.
75 Swiss 710K
W9YG
W9YG
