710K map light switch.
Alaskantinbender
Post by Alaskantinbender »
Quick question. Does the map light always stay on, or is there a switch hidden somewhere?
Mine is staying on even with the shield slid shut; it sure gets warm.
Thank you
Jim
mm58
Re: 710K map light switch.
Post by mm58 »
If you're referring to the light just above the glove compartment, there is a "hood" type switch built into the light housing. Flip the hood down and the light will go off
Sent from my SM-S931U using Tapatalk
'76 710K
