Re: more oil dripping than i would like
Posted: Wed Jun 28, 2017 5:22 am
Do you apply gasket material around the return tube ball seal? I noticed someone did previously, but found no leaks when I simply flipped it over and reinstalled.
https://real4x4forums.com/PinzgauerBBS/
https://real4x4forums.com/PinzgauerBBS/viewtopic.php?t=10937
Not quite sure what you mean there - I assume you mean the large rubber seals that seal the rocker oil return tubes where the tubes go back into engine block. If surfaces are clean you do not really need sealant on them as they squash up but as a precaution I do put a smear on them - the pushrod tubes also have a similar seal on them.audiocontr wrote:Do you apply gasket material around the return tube ball seal?
