Page 2 of 2
Re: 710k running like crap
Posted: Wed Jan 16, 2013 4:21 pm
by berger
Have you checked the timing? My distributor collar wasn't holding the dizzy on tight and it was shifting on me.
Sent from my iPhone
Posted: Wed Jan 16, 2013 4:27 pm
by buzzz
Hi Recon,
I had the same problem a while back with my 74m. After carb rebuild, fuel pump rebuild, new gas tank, Jim L advised checking the molex connection and bingo. I just cleaned it and it ran like new. would be worth a try.
Posted: Wed Jan 16, 2013 4:45 pm
by Recon113
Where might one locate said molex connection?
Posted: Wed Jan 16, 2013 5:20 pm
by pcolette
Here you go:
3-7-12 04-51 PM - Version 2.jpg (42.24 KiB) Viewed 5929 times
Remove the 2 screws that hold the plug retaining strap in place and then gently wiggle and pull the plug out. A small wire brush, an old toothbrush or preferably a Dremel tool with a wire brush can be used to clean the contacts.
Posted: Wed Jan 16, 2013 7:25 pm
Also check the back side of the contacts; often that is corroded as well.
Posted: Wed Jan 16, 2013 8:40 pm
by Recon113
I'm on it like white on rice....I was able to pull the connector and its a bit gnarly in there...I will start polishing it tomorrow
Thanks again everyone
Posted: Fri Jan 18, 2013 7:06 pm
by Recon113
Well I cleaned the molex connection and a few choice swear words...I took it out for a test drive today and it ran like a champ! I will venture a bit farther some point this weekend. Thanks everyone.....beer and chili at my house! I appreciate all the help....thanks buzzz
Posted: Fri Jan 18, 2013 8:22 pm
by buzzz
Happy that it worked for you. I wish I had asked before I did all those things to my 710m. I Now check the molex every few months just to be safe.
Posted: Sat Jan 19, 2013 12:35 am
by totaljoint
The molex connector seems to be the mother-in-law of the Pinzgauer world.....aging and prone to failure, the cause for so many problems.
Since it comes up often in posts, and is commonly unknown to new owners, I nominate the above picture for the technical section.
Posted: Mon Jan 21, 2013 2:15 pm
by Recon113
Maybe along with the picture a short or maybe long explanation as to what this connector connects and does and how it might affect everything else
Posted: Mon Jan 21, 2013 5:20 pm
by Jim LaGuardia
That information is already posted in the old archive section complete with pictures and re route for power output wire 8) .
It takes a little searching, but it's there.
Posted: Mon Jan 21, 2013 6:03 pm
by M Wehrman
Sooooo Jim,you could have just described the process... :? OH! :idea: It's that give a man a fish and eats once,teach him how to fish...Blah,blah... :lol: :lol: Did you get the Haffy dizzy pics I sent? Pic might have sucked..
Mark
Posted: Fri Apr 26, 2013 6:43 pm
by blackstack
I have the same symptoms described by recon113. I initially thought it was a fuel problem as the vehicle was idle for several months..I thought water in the fuel..So in addittion to all the things suggested to recon I also changed the fuel filter and drained the fuel tank.....Unfortunately I did not experience a remarkable recovery from cleaning the molex connection ....i am searching for the explanation of the molex function ..but aside from that ,I am stumped.....anybody know of a mechanic familiar with the Pinz in the Seattle area?
Posted: Sat Apr 27, 2013 6:54 am
by krick3tt
That was my big issue when I lived up there. Could not find anyone 'familiar' with the pinz mechanics to work on it.
Had to come to Denver.
